Author Topic: u360 Wiring Harness?  (Read 1122 times)
cadmium
  • Last login:January 03, 2021, 12:51:56 pm
« on: September 05, 2008, 05:27:35 pm »
Can anyone confirm the order of the wire colors in the u360 wiring harness?
I bought 2, but skipped the wiring harness because I had some spare mobo usb connectors lying around (same pin layout). I can make the harness, but I don't know which pin goes to which color.
If anyone could fill me in, that would be awesome. Thanks!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: u360 Wiring Harness?
« Reply #1 on: September 05, 2008, 06:07:41 pm »
Did you check the u360's install page?  It gives the order.  The only thing not clear is which side it starts from.  (I can double check when I get home.)
Robin
Knowledge is Power
cadmium
« Reply #2 on: September 05, 2008, 09:06:04 pm »
Well, it gives which color corresponds to which input/output, but judging by some (small) images of the wiring harness on the site, that order doesn't relate to which pins are which. I have a guess that I'm going to play with, but I'm hoping I don't fry my I-PAC or u360 before I figure it out.
I was just hoping someone with a wiring harness could just confirm the order of the colors.
« Last Edit: September 05, 2008, 09:08:51 pm by cadmium »
cadmium
« Reply #3 on: September 06, 2008, 12:19:02 pm »
I was able to figure it out (for the record on the first try!). To make it work, Keep joystick analog has to be checked, but whatever map you download will be what's used for the digital out.
matman
  • Last login:January 18, 2021, 02:11:39 am
« Reply #4 on: May 17, 2009, 12:21:40 am »
I want to use the pins for input (3 buttons), but also didn't get the wiring harness..is there a pin diagram that shows which pin is pin 1?  I understand what each pin is for, just not which pin is which as they aren't marked on the board anywhere...
thanks,
matt
severdhed
  • RIP Dinosaur Hippo
« Reply #5 on: May 17, 2009, 11:20:52 pm »
i'll try to remember to check mine tomorrow
matman
« Reply #6 on: May 18, 2009, 02:26:59 pm »
This is the last part on my cab i need to attach and i don't want to fry anything
severdhed
« Reply #7 on: May 18, 2009, 08:04:48 pm »
the connector has 9 pins
bottom row has 5, top has 4
bottom:
black, red, yellow, blue, gray
top
none, brown, orange, green, purple
black - ground
brown - b1
blue - b2
orange - b3
yellow - --BINGO! Either that, or I was attempting to say "before" but it was too many letters to type--
green - b5
red - b6
gray - b7
purple - b8
i hope that helps
« Last Edit: May 19, 2009, 01:55:42 pm by severdhed »
severdhed
« Reply #8 on: May 18, 2009, 11:58:10 pm »
who edited my previous post?
matman
« Reply #9 on: May 19, 2009, 02:29:04 am »
sweet!  thanks!
Donkey_Kong
    • CNC Machines
« Reply #10 on: May 19, 2009, 11:18:16 am »
The auto censor got you. Someone is attempting to save the English language from total annihilation, or maybe it's another way of saying..."Damn kids, get off my lawn!"
matman
« Reply #11 on: May 19, 2009, 01:22:20 pm »
what exactly got censored?
severdhed
« Reply #12 on: May 19, 2009, 01:52:29 pm »
you apparently cannot type the letter "b" followed by the number "4" because it thinks you are stupid and are too lazy to type the word before.
below, i will type b4, and it will automatically replace it.
