Main > Main Forum
Metal Control Panel Help
Pages: << < (3/3)
whammoed:
--- Quote from: DaOld Man on September 05, 2008, 10:35:52 am ---They cut a hole bigger than they are marked for, because they cut holes for conduit and fittings to install in.
Good point, but I'll add: That is true for ones made for conduit, but there are also punches that are labeled at the exact measurement they cut...this is the kind I have.
whammoed:
--- Quote from: GameTech on September 05, 2008, 10:41:28 am ---OK thanks for info guys... Yeah, I'm having a hard time finding something to cut such a "large" hole in this metal control panel without marking up the brand new overlay thats on it.
The buttons bezel will cover up any slight damage from the holes saw, but if you can hold out for a punch there will be less worry.
Turnarcades:
It's always going to be more difficult to work with metal panels; especially modding it from original. Patching it up is more work than with wood. If you don't feel comfortable modding the panel, consider knocking up a fresh one from wood and use a bit of filler and a sander to retain any curvature the original panel may have had.
Malenko:
a 1" conduit punch is almost perfect for button holes, on a few I took my dremel's grinder bit to make it a hair bigger but again, couldnt complain.
GameTech:
I got some of the Happs buttons... that state 1.125" opening required... Thus, I need a 1-1/8th" punch, right?
Yes, metal is nice and firm and should last forever, but adding a couple buttons is a pain...
Thanks for help.
Pages: << < (3/3)
Go to full version
