Main > Main Forum
2x360's, 1 Spintrack, 1 u-track connection help....
wilno45:
Mini-pac opti was my first choice for sure, it's a shame the 360's - which I really want, only allow 8 dedicated buttons per joystick. If they did 10 I wouldn't need an extra encoder at all. Getting the mini-pac would give me much more choice and you are right, much neater way to connect everything. Does anyone (games) actually use all seven buttons btw? I like the 3-3-1 layout most people use.
After reading another thread I am now considering putting the spinner vertically on the front of the control panel, keep changing my mind! Arkanoid is hell with my x-arcade joystick.
Thanks for the input.
Turnarcades:
The 7-button layout people choose is for Neo-Geo purists who like the 4 buttons all in a row. There's no real need for it as 6 buttons cover most bases. Don't do a front-mounted spinner, that would just be weird unless you are doing some kind of steering wheel mod.
wilno45:
The 7 button layout I was thinking of was 3 across the top 3 underneath and one at the bottom slightly to the left, a bit like the x-arcade (although that has 2 at the bottom).
No steering wheel mod for me - I am considering keeping my panel flush with the side of the arcade cabinet which will be as wide as the doorways in my house allow. This means horizontal space (with a trackball centered) is at a premium although the spinner would normally be above the joysticks and I suppose be out the way anyway.
scotthh:
The Spintrack "USB Version. Has 3 Mouse button connection". Now you're only short one button. I couldn't figure out if the U-Trak USB comes with mouse button inputs.
It's $7 extra for SpinTrak USB. It's $14 extra for U-Trak USB. So you "save" $21 getting the non-USB versions. The OptiPac ($39-$21=$18) has 4 mouse buttons. I thinkyou can use them all, getting the 20 buttons you want. The Mini-PAC Opti ($69-$21=$48) is your most expensive option, but it is the most versatile.
BrianP:
--- Quote from: scotthh on September 06, 2008, 12:35:28 pm ---I couldn't figure out if the U-Trak USB comes with mouse button inputs.
I send an email to Ultimarc asking the same question. Here was Andy's repsonse:
--- Quote ---The current version does not support mouse button connection. One way to get
mouse buttons is to use the Mousekeys function, which is described in the
Windows help.
So, you won't get the mouse buttons there. But if the SpinTrak supports it, you don't need it with the U-Trak.
