Main > Everything Else
Spackling sucks!
Blanka:
--- Quote from: TOK on September 05, 2008, 06:01:10 am ---That actually looks kind of cool. I doubt its in the US, but I'd like to read up on it. You stucco interior walls?
These "lego's" are pretty nifty. They hold 5 stories with ease, they damp temperature change a lot (less airco needed). And yes we stuco them inside. Not the grainy-german-lederhosen-house-look way of stuccoing, but just fine grain like gypsum painted white without board-lines. And regarding the LEGO, you order them with a building plan and all blocks CNC'ed to perfect fit.
TOK:
Pretty cool. Those same ones are used for both interior and exterior walls? The idea of a trouble free wall and surface is appealing, but how do you handle any post-wiring?
Blanka:
No, these blocks are construction/interior only.
Next layer is 65mm Kingspan Kooltherm (RC=4!), same insulation as 250mm rockwool!
Then 20mm air.
Then this
I like these modern black bricks 200x200x70mm.
They are pretty precise in measurements, so they can be glued as well. It will give you 1mm seams only.
Pipes are inserted with this before stuccoing:
The two blades cut a slot for the plastic pipes.
Mostly we insert some empty pipes as well for future wiring.
Navigation
[0] Message Index
[*] Previous page
Go to full version
