Author Topic: PC Power Supply to Bench Power Supply Mark II  (Read 1906 times)
somunny
  • Is it hot in here?
« on: September 03, 2008, 09:48:27 pm »
This is the second power supply I've converted using this tutorial.
The fan on the top was relocated from inside to make space for the wiring.  I still need to add some feet and label the outputs (gotta order some 'white on clear' label tape for the P-Touch).
Outputs: yellow=+12VDC, blue=-12VDC, black=ground, red=+5VDC, white=-5VDC
These really come in handy when you need to test LED arrays.
SavannahLion
Re: PC Power Supply to Bench Power Supply Mark II
« Reply #1 on: September 03, 2008, 11:44:24 pm »
LOL. That's funny that they have a tutorial. Honestly, I never really thought to use posts and cut everything short like that. I have a PSU buried somewhere where I built a harness that's simply shorted with a jumper and added pigtails and alligator clips. Basically a fire hazard waiting to happen.  >:D
Thanks for the link, there's a few ideas I never really considered before.
« Reply #2 on: September 05, 2008, 01:11:19 am »
I have an old AT power supply that would be perfect for this.
abzman2000
  • Last login:August 26, 2020, 06:25:12 pm
  • I LIKE my hat!
« Reply #3 on: September 05, 2008, 04:01:59 am »
what about 3.3? I find that good for lots of things
Ed_McCarron
« Reply #4 on: September 05, 2008, 10:05:55 am »
Nice site.  They also had this:
http://www.wikihow.com/Build-a-Shed
Could be handy for some folks around here.
« Reply #5 on: September 05, 2008, 10:48:31 am »
This reminds me of my shed project 6 years ago.
I used a concrete floor, which is great. Only complaint I have is it is way too small.
its 12 foot by 16 foot, wish I had made it at least 16 by 20.
  • Last login:February 22, 2026, 06:49:16 pm
« Reply #6 on: September 05, 2008, 11:17:17 am »
I checked and unfortunately they do not have a tutorial on hauling wood in a pickup truck.
  ;D  :applaud:
SavannahLion
« Reply #7 on: September 05, 2008, 01:09:23 pm »
Be careful. Some city codes have specific limitations on number of sheds, size of sheds and location of sheds. Even if it is a "floating" shed like in the tutorial. Even worse, some city codes have a limitation on how high a shed could be be above a fence line! IOW, a short fence means a short shed.
somunny
« Reply #8 on: September 05, 2008, 01:12:13 pm »
I didn't include it on the the last one I built and never missed it so 3.3V didn't make the cut this time around either.
The 3.3V wires are cut back and rolled up inside if I ever had the need for them.  I mostly use the 12V and 5V.
Ed_McCarron
« Reply #9 on: September 05, 2008, 01:44:54 pm »
At least PBJ got the joke... :)
