Main > Main Forum
LED Wiz wiring question
thatitalian:
--- Quote from: scotthh on September 03, 2008, 09:42:18 am ---
--- Quote from: thatitalian on September 03, 2008, 07:03:35 am ---
See my diagram below. On the left is a daisy chain connected to the ground of a button, and on the right is a wire nut daisy chain, but how do you connect that to the ground or to anything for that matter?
Maybe I am just missing something, in which case if I am I apologise for being a dumb *ss!
Ah, now I SEE your question. Not dumb. Look more closely at the picture Games001 attached, there are 3 wires connected and twisted inside the wire nut.
Ahhhhhhhh!!! Now I see! This is actually a really good idea as in theory you could wire several button grounds into one nut and just have a wire from that nut running to the ground! No?
arzoo:
--- Quote from: thatitalian on September 03, 2008, 11:34:37 am ---Ahhhhhhhh!!! Now I see! This is actually a really good idea as in theory you could wire several button grounds into one nut and just have a wire from that nut running to the ground! No?
Yes!
stephenp1983:
So say I went with the electric ice buttons and the rgb drives. I would hook the three wires to the terminals on the led wiz, and the the forth wire from each of my six buttons could all be twisted together into one wire nut and have one wire run into the u5v terminal? I wouldn't have to daisey chain one wire to the next?
and if I was only using the usb power I wouldn't need to run anything to the ground terminal right?
arzoo:
--- Quote from: stephenp1983 on September 03, 2008, 08:11:49 pm ---So say I went with the electric ice buttons and the rgb drives. I would hook the three wires to the terminals on the led wiz, and the the forth wire from each of my six buttons could all be twisted together into one wire nut and have one wire run into the u5v terminal? I wouldn't have to daisey chain one wire to the next?
Correct. :)
Edit: This was my 666th post... creepy!
thatitalian:
--- Quote from: arzoo on September 03, 2008, 09:04:27 pm ---Correct. :)
DON'T LISTEN TO HIM! HE IS THE DEVIL IN DISGUISE >:D
Do not stare directly into the beasts eyes!!! (not that you are a beast, I can't comment, I have never seen you before! ;D)
But seriously, this is very good knowledge that I now possess!
