Author Topic: Control buttons question  (Read 1379 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: August 31, 2008, 08:43:55 pm »
Hi guys im in the final stages of the construction of my control panel and have a few questions regarding some buttons I have found on the internet.
Here is a link to the site: http://www.happcontrols.com/pushbuttons/5400045x.htm
My question is this can i use this button it looks like it has a standard cherry switch style connector and if this button can be used how would I illuminate it?
Many thanks
Ginsu Victim
  • Comanche, OK -- USA
Re: Control buttons question
« Reply #1 on: September 01, 2008, 12:32:19 am »
The white part that's holding the microswitch is also an LED holder. It uses a T3-1/4" wedge style.
Marky_1979
    • Personal Webspace
« Reply #2 on: September 01, 2008, 05:20:10 am »
Thanks mate next question how do i give power to the led?
thatitalian
  • The Revolution Is Coming...
« Reply #3 on: September 01, 2008, 07:53:58 am »
Depends on the led you are using.
Normally a 5v led (with the correct resistor) you can power using the led wiz or the red 5v wire from your PSU , but a 12v led you would need to use the power from a molex connector (splicing it if you do not have large amounts of molex connectors, like myself).
Ginsu Victim
« Reply #4 on: September 01, 2008, 11:31:55 am »
Easiest just to hack a USB cable.
Marky_1979
    • Personal Webspace
« Reply #5 on: September 03, 2008, 08:04:12 pm »
How do I do this mate? Im looking at hooking up 3 of these buttons also description of product is : Rectanglar, 14V #161 lamp, .250 micro
so looks like I need 14volts
Ginsu Victim
« Reply #6 on: September 03, 2008, 08:37:07 pm »
12v will do it. Just use a molex connector from the computer PSU and cut off the end. Use the yellow wire (12v) and either black wire (ground).
Marky_1979
    • Personal Webspace
« Reply #7 on: September 09, 2008, 06:30:33 pm »
How would i use this for 3 buttons would I need to a daisy chain with yellow and black wire?
