Main > Everything Else
Atkins Induction
saint:
50 pounds in 3 weeks == go see your doctor and make sure you don't have a problem. That's insane.
FrizzleFried:
I low carbed it 4 years ago. It took me 3 months to lose 50 lbs. It took me 3 years 8 months to put it back on. I am going back on the low carb diet next week (after a birthday party on Sunday). If I can suffer for 3 more months to lose 50 lbs again, only to take over 3 and half years to gain it back....worth it IMHO.
When I first low carbed it, I lost 20 lbs in 2 weeks...then it slowed down....
patrickl:
It depends on the weight you started with. An elephant could lose 50lbs by taking a dump.
Xiaou2:
I would think that if all you ate was meat... your body wouldnt have enough
vitamins. It wouldnt need a lot of the meat - as it would look for vitamins... and
thus most of the meat would simply be put out as waste... while the body tried to
feed off the fat and itself - to gather enough vitamins to keep going on as normal.
(basically, the body would be starving, and degrading)
Lower carbs and lower fat intake + Exercise = much better for you... Imop.
ChadTower:
I trained for and ran a triathlon... lost 10lb and actually ate a whole lot more than I usually do. :)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
