Author Topic: Anyone know what joystick they used in killer instinct 2?  (Read 1195 times)
bigdog1977
  • Last login:June 16, 2009, 01:32:48 am
« on: August 26, 2008, 07:31:50 pm »
Looks almost like a Happ comp. Trying to find something that will mount the same as these. What would you guys recommend?
« Last Edit: August 26, 2008, 10:55:08 pm by bigdog1977 »
These arnt the droids your looking for...
  • Last login:Yesterday at 08:24:26 am
Re: Anyone know what joystick they used in killer instinct 2?
« Reply #1 on: August 26, 2008, 07:45:15 pm »
My MKII and KI2 use different stick then that, close but not the same.  I dont know which ones are in there and the battery in my camera is dead. I will take pix ASAP for you
bigdog1977
« Reply #2 on: August 26, 2008, 08:04:37 pm »
cool thanks, The game currently had capcom vs snk installed. But after sanding down the cab I found it was originally Ki2.
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #3 on: August 26, 2008, 11:35:08 pm »
If you're concerned with something that will mount the same (so you don't have to drill new holes and patch old ones?), why not remove the joystick and measure the distance between the holes? On Happ's site they have the measurements for the comp stick. If you want a comp stick and the holes line up, you're good to go.
jcoleman
  • Last login:April 23, 2024, 09:05:19 pm
  • RTFM
« Reply #4 on: August 27, 2008, 07:58:13 pm »
Definitely Happ Competitions.  Most sticks have the same mounting template nowadays; you're probably safe with just about anything.
bigdog1977
« Reply #5 on: August 27, 2008, 08:44:58 pm »
Okay thanks guys for the help! I just ordered 2 happ comps.
« Reply #6 on: August 27, 2008, 10:46:11 pm »
didnt get pix, but they are indeed happ comps
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #7 on: August 28, 2008, 03:41:59 pm »
If you want exact replacements for older Happ comp sticks you want iL Eurojoysticks.
