Author Topic: I-Pac problem with MAME  (Read 1224 times)
Pete Rittwage
  • Last login:October 08, 2020, 09:51:02 pm
« on: August 24, 2008, 04:20:17 pm »
Hi guys,
I've had an old I-Pac for years (whenever they first came out) but lost my cabinet to flooding many years ago.
Anyway, I rebuilt it into a new cab recently and am reminded of a problem I always had with it.   When playing two-player games (Mortal Kombat II, for example) there is some combination of buttons that the Player 2 controls does that causes MAME to quit like you pressed the escape sequence (normally hold P1 and press P2).   I have two IPacs (mine and a friends) and I swapped them, but the same problem persists.
They are setup to the default config, and I guess I need to sit down and see if I can find the exact combination, but I can play P1 controls against the PC all day, it's only some combination of the P2 controls.
Anyone else ever have this problem?  I have all keys mapped as the defaults and no shorts in the wiring.  This used to happen on my old cab with an entirely different control panel and PC.
Pete
Jack Burton
  • Last login:August 26, 2023, 11:32:31 pm
Re: I-Pac problem with MAME
« Reply #1 on: August 24, 2008, 05:20:50 pm »
The exact same thing happens to me.  I'm using the default layout for the i-pac, with the newest version of Advancemame.  It seems to happen most during super street fighter 2 turbo.
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #2 on: August 24, 2008, 05:53:00 pm »
You (both) need to reprogram the Shift function as it defaults to exit when pressing P1 and P2 start.
From the Ulimarc website:
SHIFT MODE
Pressing and holding 1player start enables shift mode with access to the following keys (when "MAME" setting is used):
2 player start=Esc – for jumping back to the menu
Joystick left=Enter – for running games in Windows and for MAME game config menu
Joystick right=Tab – for entering MAME config menu
Joystick up=~ - for entering MAME volume/gamma menu
Joystick down=P MAME pause key
1 fire (button 1)=5 – for simulating coin insert.
Pete Rittwage
« Reply #3 on: August 24, 2008, 06:03:41 pm »
When this happens, nobody is pressing the P1 or P2 start buttons.  Using regular joystick + 6 buttons on P2 causes the issue to appear.
I'll get on the machine tonight and see if I can make it happen reliably.  It's also possible that it's a combination of P1 and P2 controls causing it, but we're definately not pressing the P1 or P2 buttons when it happens.
Paul Olson
  • Last login:May 07, 2024, 03:19:08 pm
    • Paul's Arcade
« Reply #4 on: August 24, 2008, 06:19:11 pm »
If I remember right, it is a problem with using ctrl and alt in the default config. Try remapping to something else and the problem should go away.
Pete Rittwage
« Reply #5 on: August 24, 2008, 06:31:10 pm »
Actually, this turns out to be a MAME problem, not iPac or the config.
For sure, if you play MK2r14, and press any button you map as P2 button 6 in MAME, it crashes.  Other revisions of MK2 don't do that, nor does MK1 and MK3.
Weird- I'll post it on the MAME bug list.
« Last Edit: August 24, 2008, 06:49:28 pm by Pete Rittwage »
Hoopz
« Reply #6 on: August 24, 2008, 07:21:55 pm »
Sorry, I read your initial post and misunderstood it.
What version of Mame are you running?
Jack Burton
« Reply #7 on: August 25, 2008, 07:49:31 pm »
Yes, I will also add that this happens to me while no one is pushing P1 or P2 start.
Also it happens in Super Street Fighter, so the sixth button thing can't be the cause either.
As for Ctrl and alt being mapped, I will remap my buttons with the I-pac configuration tool and see if that solves the problem.
