Main > Main Forum
What to do with my ultracade 33" cabinet??
Pages: << < (3/3)
Axe:
Although if it is a showcase cab (which the 33's are right?) then a MVS system might suck unless you can get a 4 or 6 cart board, getting in behind those things would be annoying just tot change out a cart.
Do you have all the controls from before? is it still wired up as a jamma+ control set?
madgammer:
The cab came with all the wiring etc, just not the board so it still has all the cables and even the I/O card for the controller.  Since I work in IT I have a nice rack mount server that I can propbably use as the PC so that's not going to add to the upfront cost at all.  It's not a NEW server, but it's only about 2-3 years old.
davidrfoley:
then all you need is a JAMMA to PC board and you can run your PC Software on the machine.
madgammer:
could I use the Quantum3D JammaLinx coin-op I/O adapter that it came with?  If not do you happen to have a link to a good board that I can use.
--- Quote from: davidrfoley on August 26, 2008, 01:38:34 pm ---then all you need is a JAMMA to PC board and you can run your PC Software on the machine.
davidrfoley:
Yes, that board converts JAMMA to PS/2 Keyboard and PS/2 Mouse.  NanoTech Entertainment sells the RETR-IO which converts JAMMA to USB Mouse and Keyboard.  UltiMarc makes the JPAC.
Pages: << < (3/3)
Go to full version
