Main > Main Forum
Will PS2 and USB trackballs/spinners work together?
u_rebelscum:
--- Quote from: AlanS17 on June 10, 2003, 11:46:47 pm ---Well I know USB devices work together... but will a PS2 trackball work with a USB spinner???
Any USB-PS/2-serial combo should be fine. The only thing you need to worry about is if moving device A while playing a game with device B will mess up the game play or not.
If you won't use both on the same game trying to control two different things at the same time, don't worry, you're fine. :)
If you want to use the TB and the spinner at the same time, with your PS/2 + USB setup, the USB spinner will also control everything your PS/2 TB is controlling; ie: no dice. :(
AlanS17:
That's all I wanted to know. I don't plan on using the 2 at the same time. Will this same setup work in WinXP?
u_rebelscum:
--- Quote from: AlanS17 on June 11, 2003, 12:08:48 am ---That's all I wanted to know. I don't plan on using the 2 at the same time. Will this same setup work in WinXP?
Yup.
AlanS17:
Screw it. I'm moving back to XP... I had forgotten how much I hate Win98, and those Act Labs GS guns blow anyways. They don't work right. I feel cheated from that Ebay dude. (And to add insult to injury he gave me a positive feedback on how quickly I paid.)
