Main > Everything Else
Basement exterior door
<< < (3/3)
Blanka:
--- Quote from: kingflynn on August 27, 2008, 03:51:06 pm ---You're right.  99 percent of entry doors are fiberglass or steel with foam cores.  It's best just to order the door cut down from the factory, because they cut the jambs too, and it will come as a prehung unit.
Nice trans-atlantic difference here! Fiber glass is not very well received in Brussels. The material is very bad for recycling. The main reason why the Eames Plastic Chair is Polyethene now instead of FG. Besides, composites do very bad in local building regulations. They give you major 'bad' points on the sustainable materials check lists.
Here housing doors are 90% multiplex (with a sheet of aluminium for real stiffness), 10% solid wood I guess (the classic models).
ChadTower:
--- Quote from: boykster on August 28, 2008, 12:53:19 am ---I have a wood with glass inlay exterior door as my front door.  Its wood and glass - no fiberglass or steel involved.  And yes, it has 12 coats of valspar urethane on it.
My front door is wood and glass... no urethane, though, just paint.  It doesn't matter that much behind a storm door.
Navigation
[0] Message Index
[*] Previous page
Go to full version
