Main > Main Forum
TV extremly fuzzy using computer
CodeWhite:
Chicago,
Im curious as to what was the problem you were having with your x800 pro when you tried to connect it to the TV with the supplied adapter. The reason why I ask this is because the computer in my cab also has an x800 pro installed in it. I just recently tried to hook it up to my cabs TV component inputs using the adapter that came with the card (the one that fits into the DIN connector on the card) , and I get a clear picture but its tinted blue. :angry: I tried setting colors using the cards adapter settings but no dice. It seems it has something to do either with the cables I am using or the card's output. I just wanted to know if your problem was similar and I should just buy a dvi to component adapter.
ChicagoDave:
Yes, I was getting a blue tint problem as well. Buying the DVI to Component dongle solved the problem. You can look at the details of my original post here:
http://forum.arcadecontrols.com/index.php?topic=69922.0
CodeWhite:
Thanks for the quick reply man. My next question is: Did you buy your DVI to component dongle directly through ati? Or will a generic one work fine. Since the x800pro is discontinued it is a major pain in the rear to find any genuine parts for the thing.
I appreciate the help.
ChicagoDave:
--- Quote from: CodeWhite on September 22, 2008, 10:17:15 am ---Thanks for the quick reply man. My next question is: Did you buy your DVI to component dongle directly through ati? Or will a generic one work fine. Since the x800pro is discontinued it is a major pain in the rear to find any genuine parts for the thing.
I bought a generic one at Fry's and it worked fine.
Ummon:
Or, you can buy this one, if it happens to be less (this is the one that's been passed around here for a while) : dongle
