Main > Main Forum
Y spliter for a PSX2 controller?
Les:
--- Quote from: Hoe on June 09, 2003, 10:10:39 pm ---Errr, it seems he's asking for one to make one controller, go into two consoles. Most likely so he dosn't need to unplug, then replug it into another console using some form of adaptor for the second. I doubt <i>they</i> make adaptors, but you probly can :P
Basically you are correct. Here is a synopsis of my design. I want to have a PSX2 and another console (be it a Dreamcast, XBOX, or other) both connected to my arcade controls and a set of 2 PSX2 gamepads. This is so I can play my PSX2 and other console on my control panel or traditionally with gamepads. If possible I only want one set of gamepads controlling both consoles.
armad1ll0:
I could probably make you one for $25 shipped. You want it double on the female end or the male end?
Les:
--- Quote from: armad1ll0 on June 10, 2003, 01:39:14 pm ---I could probably make you one for $25 shipped. You want it double on the female end or the male end?
I can hack it myself just fine. I was just wondering if there might be a ready made unit in existance.
