Main > Everything Else
Photoelectric switches for outside lights
Ed_McCarron:
http://www.smarthome.com/4259W.html
Light switch style, can be programmed for on at dusk, off at dawn, and looks like it'll do on at sunset and off at a particular hour - the example in the manual shows on at sunset, off at 10 pm.
Table based, not photocell tho...
2600:
They make a photo-cell that you plug into where the bulb goes and then plug the bulb into that as well.
kinda like this
photocell
DrumAnBass:
I have this Intermatic - also comes pre-programmed with sunrise and sunset times; works well. Had to change it's batteries after a couple of years of service.
http://www.amazon.com/gp/product/B000QD9QLA
Edit - Bought this because the photocell "under the bulb" switches sucked....
ahofle:
--- Quote from: Ed_McCarron on August 08, 2008, 12:49:01 pm ---http://www.smarthome.com/4259W.html
That looks like a winner there. If my switch only controls 3 60 watt lights outside, is it OK to get the 2400 watt one? They also have a 40-500 watt version for the same price.
Ed_McCarron:
Go with the smaller one then - its probably just a different sized relay/scr/whatever in the case.
Navigation
[0] Message Index
[*] Previous page
Go to full version
