Author Topic: Building a MAME LanBox which case do u like best?  (Read 1732 times)
Gavica
  • Last login:March 05, 2011, 09:56:15 am
« on: August 07, 2008, 10:25:30 am »
I'm building a MAME Lanbox to put all the games in, but still debating over which case to get, which one do u guys think looks nicer and is better??
Note: I have a spare PSU, so it doesnt matter if it comes with one or not.
Antec NSK1380
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129038
Thermaltake LANBOX Lite VF6000BWS
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133044
  • Last login:Yesterday at 08:03:14 pm
Re: Building a MAME LanBox which case do u like best?
« Reply #1 on: August 07, 2008, 10:29:14 am »
Thermaltake, definately.
Also, it has more (and better) reviews than that other case.
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
« Reply #2 on: August 07, 2008, 11:11:02 am »
I second the Thermaltake LANBOX. Not just for looks but if your planing on using your spare PSU, I'm 99.9% sure that the Antec NSK1380 does not use a standard PSU. So fitting you spare PSU may require some dremel work or it may not even be possible. It does come with a PSU, but if its not good enough for you or it goes out, replacement would be difficult and probably more expensive then it needs to be. Just my 2cents....
bemerritt
  • Last login:August 21, 2008, 02:45:22 am
« Reply #3 on: August 07, 2008, 11:47:42 am »
third
Gavica
« Reply #4 on: August 07, 2008, 02:17:43 pm »
this is the spare PSU I have, will it fit on the Thermaltake box?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023
Can those lanbox cases fit any PSU? or they need to be a special size.
« Reply #5 on: August 07, 2008, 02:20:02 pm »
Any ATX power supply (which is what you have) should fit in that Thermaltake case.  Dew eet!
Gavica
« Reply #6 on: August 07, 2008, 02:33:21 pm »
thanks guys
Paul Olson
  • Last login:May 07, 2024, 03:19:08 pm
    • Paul's Arcade
« Reply #7 on: August 07, 2008, 04:50:11 pm »
I was looking at those a couple of weeks ago. They are much bigger than I thought they would be. I ended up going with a small atx case instead since it had a smaller footprint in the cab.
ahofle
    • Arcade Ambience Project
« Reply #8 on: August 07, 2008, 04:57:07 pm »
I was just going to say, what's the point of those cases?  Are they supposed to be more portable than a normal case?  Because they look the opposite to me.  As mentioned below, they also seem to take up more desk/floor space.   ???
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #9 on: August 07, 2008, 10:55:15 pm »
One good aspect of these: they are an easier shape/size to carry under your arm than some designs. If was going back to MATX for portability though; I would probably get a case with an OEM handle like one of these, or this, or I would add a handle onto a shuttle XPC.   Handles are just so dandy handy.
ahofle
« Reply #10 on: August 07, 2008, 11:37:51 pm »
Still seems much easier and cheaper to just get a cheap ATX carrying strap:
http://www.outletpc.com/c0679.html
NickG
  • Dig.
    • My Projects Page
« Reply #11 on: August 08, 2008, 04:19:27 am »
Straps are handy, too.  My Antec "Super Lanboy" case came with one, so that it is what I currently use.  I would go back to the MATX train (and my old Aspire Q-Pack which is collecting dust) but I can't seem to find an affordable one with the same features as the full ATX boards.
