Author Topic: Monitor Bezels for LCD monitors?  (Read 7220 times)
cmoses
« on: August 05, 2008, 10:28:17 pm »
Does anyone know where you can get black plastic monitor bezels for LCD monitors?  I always see ones for CRT tube monitors, but these are curved.  I need something that will work for a LCD monitor and that is flat.  Anyone have any suggestions?
testicle187
  • Last login:September 21, 2022, 09:34:53 am
Re: Monitor Bezels for LCD monitors?
« Reply #1 on: August 05, 2008, 11:05:04 pm »
Painting the plexiglass that sits in front of the monitor is the easiest method.  Most LCD monitors seem to be widescreen, so finding a Happ Bezel might be difficult.  If your monitor is not widescreen and is a standard arcade monitor size they normally sell different bezels for flat screen monitors as well.
cmoses
« Reply #2 on: August 06, 2008, 12:23:23 am »
I am building a MAME machine and am going to use either a 19" or 20" LCD standard 4:3 aspect monitor, NOT a widescreen.  I have a smaller cabinet and could only get a 21" CRT in there at the most and they end up being usually about 19.8 viewable anyway.  So I figured I might as well go LCD and get almost the same or slightly larger display and not have all the weight.  So that is why I am looking for a flat screen monitor bezel.
When you mentioned painting the plexiglass in front of the monitor.  I assume you mean painting the outsides of the plexiglass black where the monitor does not show in order to create a bezel and hide any monitor plastic.  Or are you referring to using tinted glass or plexiglass so that it all appears dark except for where the monitor is showing through?
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: August 06, 2008, 10:00:19 am »
Actually, using the method mentioned, you paint the back side of the glass, not the side facing out. It gives a beautiful, mirror-black finish when done right.
GAtekwriter
  • Last login:July 16, 2011, 09:55:44 am
« Reply #4 on: August 06, 2008, 10:09:01 am »
I cut my own from black foam board that stays flat.
http://forum.arcadecontrols.com/index.php?topic=67651.msg792530#msg792530
Jim
Ginsu Victim
« Reply #5 on: August 06, 2008, 10:35:00 am »
  • Last login:Yesterday at 07:54:28 pm
« Reply #6 on: August 06, 2008, 11:54:13 am »
Jim
Thirded (well, I used matte board - black with a black core - $3.75).  With the gray tinted glass on top it looks amazing.  CHECK IT OUT.
Blanka
« Reply #7 on: August 06, 2008, 02:50:33 pm »
Better yet than painting glass is putting a black sticker on the back side. It's way more even than paint.
Ginsu Victim
« Reply #8 on: August 06, 2008, 03:05:13 pm »
My spray painted plexi on my CP looks perfect with no effort (mirror finish). Just sprayed one side black and it's gorgeous.
Lot easier.
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« Reply #9 on: August 06, 2008, 03:24:39 pm »
I bought this bezel from Happ...
http://www.happ.com/monitors/49271500.htm
It's flat.... not curved.
I'm using it on a CRT monitor but it should be fine with an LCD...
Now... the problem is... finding that 4:3 27" LCD monitor.  :o
... Why is it that you always find it in the last place that you look? ...
severdhed
  • RIP Dinosaur Hippo
« Reply #10 on: August 06, 2008, 05:05:06 pm »
i spray painted the back of my plexi and it turned out great.  i even just used $1 flat black spray paint from wal-mart.
