Author Topic: flipper buttons without springs?  (Read 1895 times)
Broken
  • Last login:October 22, 2012, 04:29:02 pm
« on: July 28, 2008, 11:04:31 am »
Shorten Those Links!
how exactly does a button work without a spring?
« Last Edit: July 28, 2008, 12:51:18 pm by Peale »
Ginsu Victim
  • Comanche, OK -- USA
Re: flipper buttons without springs?
« Reply #1 on: July 28, 2008, 11:05:57 am »
Removed by Ginsu Victim, since the link didn't work originally, and my response was dealing with microswitches, not leafs.
« Last Edit: July 28, 2008, 11:59:28 am by GinsuVictim »
Broken
« Reply #2 on: July 28, 2008, 11:10:12 am »
Link is messed up. You can use a pushbutton without a spring, relying on the microswitch to bounce the button back, it's just not recommended.
its a leafswitch button.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: July 28, 2008, 11:14:41 am »
Same principle as what Ginsu is talking about -- depending on the game, I'll pull the springs on a leaf button to reduce resistance and my Asteroids actually came that way.
Working: Not Enough
Projects: Too Many
Progress: None
RandyT
  • Last login:Yesterday at 11:46:17 am
    • GroovyGameGear.com
« Reply #4 on: July 28, 2008, 11:15:14 am »
Why is it "not recommended"?
This little trick has been known around here for quite some time.  It is "highly recommended" that people try doing this with their buttons if they feel that they are too stiff.  This especially holds true with some of those "non-Cherry" switches out there that require high actuation forces.
If you don't like it,  then it's not for you.  But more than one person has decided not to put the springs back.
RandyT
Ginsu Victim
« Reply #5 on: July 28, 2008, 11:20:58 am »
Man, you're on ---my bottom--- today...
Anyway, I could see using not spring with a Sanwa switch or other stiff microswitch, but I've tried it with Cherries and it's just a tad too sensitive.
When I said it's not recommended, I meant by me, not the general concensus. I should've made that clear.
« Reply #6 on: July 28, 2008, 11:28:13 am »
You can always just snip the spring in half for less resistance, too.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #7 on: July 28, 2008, 12:47:01 pm »
Like the best women, get ones that have a cherry.  ;D
Ginsu Victim
« Reply #8 on: July 28, 2008, 01:06:14 pm »
Uhhhhhhh.......hide your daughters......
Broken
« Reply #9 on: July 28, 2008, 04:30:17 pm »
appreciate responses, so how do i remove the spring on leaf buttons?
Ginsu Victim
« Reply #10 on: July 28, 2008, 04:33:24 pm »
It has an e-clip on bottom. Pop that off and the plunger will come out. Just remove the spring and reassemble.
Broken
« Reply #11 on: July 28, 2008, 04:43:57 pm »
my leafs dont have e-clips. havent seen a leaf with an e-clip before.
Ginsu Victim
« Reply #12 on: July 28, 2008, 04:49:40 pm »
Mine do.
Broken
« Reply #13 on: July 28, 2008, 11:15:29 pm »
is it even possible to remove a spring on a leaf switch without an e-clip.
RandyT
« Reply #14 on: July 29, 2008, 12:58:12 am »
I'm only familiar with the old school type that had the clips.  What do these use to keep the plunger from flying out of the bezel?  Is a photo or at least a description of the mechanism possible?
If it looks like squished plastic or a glued on part, then they are most likely sealed so the spring couldn't be removed without ruining them.
RandyT
Broken
« Reply #15 on: July 29, 2008, 01:07:37 am »
picture  http://www.pbresource.com/buttons/de-500-5026-32.jpg
as you can see the tip is slightly wider than the shaft and it seems to be glued on, like you said.
Ginsu Victim
« Reply #16 on: July 29, 2008, 09:32:15 am »
Which is what I have. More than likely Wicos.
Broken
« Reply #17 on: July 29, 2008, 11:37:56 am »
where can i buy these types of leafs?
i've tried lizardlick and just about every shop in the UK.
