Author Topic: **2008 BYOAC Token BACK SIDE Design Thread**  (Read 17137 times)
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:December 23, 2023, 07:05:04 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« on: July 20, 2008, 09:33:27 pm »
This thread is for the design discussions and proposals regarding the back(reverse) side of the 2008 BYOAC token.
We are designing  .984" (25mm) tokens.  So that all entries are judged equally, submissions should be in grayscale only, without bling. (Bling refers to color, photorealistic renderings. If we get a volunteer to bling all entries at the end equally, we can do that.)  White should indicate the lowest point of the token, black the highest.  If you want to show partial-height details use shades of gray, Different levels of gray are OK.  Of interest as you design,  the 'lowest' or 'deepest' point on the token will usually be shiny because it doesn't require machining.
So that those of us who are not Photoshop Gurus are given a fair shot , no 'blinged' renderings should be posted.
Guidelines/Rules
-No R-Rated material
-No trademarked or copyrighted images. (Pacman, etc...)
-MAME references are OK though, we have approval to use the logo if we like as long as we respect the spirit of MAME - i.e. no references to playing thousands of games, etc.
-No Bling - refer to the 2004 thread below to see how blinged line art turns out.
-Should display "Build Your Own Arcade Controls" (or at least "BYOAC") and the www.arcadecontrols.com URL   because BYOAC is the whole point of the tokens.
-If at all possible you should have your art in vector format. (Adobe Illustrator AI for example.)  Next best is very high-res raster (Hi-res meaning greater than or equal to 300DPI,) but I discourage it because we have always used vector with superb results.  Low-res artwork won't work, you will need to have someone fix it up for you.
-Vector fonts need to be converted to curves.
- .002" is the absolute minimum line width.  While lines can be reproduced at this scale, text may not be readable for being too small.
-The 'lowest' or 'deepest' point on the token will usually be shiny because it doesn't require machining.
If you are submitting what you consider your final proposal, please say so in your post. Otherwise we will assume you are submitting it for group discussion and tweaking.
This is a good sample from 2004:
Here are previous years' threads for reference.
2007 Back
2006 Front
2006 Back
2005 Front
2005 Back
2004 combined thread
Go for it!
« Last Edit: July 20, 2008, 09:41:15 pm by Santoro »
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:May 04, 2024, 09:08:32 am
Re: **2008 BYOAC Token BACK SIDE Design Thread**
« Reply #1 on: July 21, 2008, 12:42:18 am »
WOOT!
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
dstone
  • Last login:January 14, 2021, 01:03:52 pm
    • Vectorcade
« Reply #2 on: July 21, 2008, 02:06:10 pm »
Re-worked this one for 2008. I'm interested in seeing what all crops up this year!  :cheers:
« Last Edit: July 21, 2008, 08:10:43 pm by dstone »
« Reply #3 on: July 27, 2008, 05:18:26 pm »
Oh cool, I was wondering when this would start again.
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #4 on: July 27, 2008, 06:26:28 pm »
Here are my 2 favorites from my last submissions...
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
  • Last login:May 23, 2021, 12:53:30 pm
« Reply #5 on: July 27, 2008, 07:18:00 pm »
Just thinking out loud here:
The BYOAC blocks a few in the army of 1-ups on the first design... If the flip side has BYOAC on it, then you can probably omit the BYOAC on this side...
« Reply #6 on: July 27, 2008, 08:38:15 pm »
You could probably get rid of the comma.  There is no need of one there.  Simplifies and saves a little textspace and it looks really weird right at the top center of the coin.
vorghagen
  • Last login:September 05, 2017, 01:06:59 am
« Reply #7 on: July 27, 2008, 10:33:13 pm »
I still think jfunks '1up army' design is one of the best of any year and would love to see it on a token.
Of the two you've posted here I prefer the second because of
1. The font. A little easier to read and seems more arcadey.
2. The lack of the BYOAC, for reasons specified by missioncontrol.
3. The notches around the outside. Something about them I just really like.
Never argue with an idiot, he'll just drag you down to his level and beat you with experience.
« Reply #8 on: July 28, 2008, 10:55:12 am »
Yeah, I like tokens that have that coin style lip around the edges.  Makes it feel like it has more value somehow.
sez
  • Last login:April 25, 2012, 05:57:20 am
« Reply #9 on: July 31, 2008, 05:42:37 am »
Back_take 3
Eat your greens
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
« Reply #10 on: July 31, 2008, 06:14:31 am »
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
thatitalian
  • The Revolution Is Coming...
« Reply #11 on: July 31, 2008, 07:00:13 am »
I agree completely with this.
Font is way better, but do omit the comma, looks a little odd.
It is better to have BYOAC omitted from one side just to have more space to play with.
Overall the design and slogan are really awesome!
« Reply #12 on: August 01, 2008, 02:04:22 pm »
Back_take 3
Why is the Y so huge and the C so little?
sez
« Reply #13 on: August 03, 2008, 06:18:22 am »
Back_take 3
I wanted to create a hanging vine kind of look yet also wanted to keep the "arcadecontrolscom" text quite separate from the BYOAC text.  To have the "C" considerably smaller than the "Y" is because the C blends beautifully into the A.
There you go!  Clear as mud  :laugh:
Sez.
« Last Edit: August 03, 2008, 06:21:34 am by sez »
Eat your greens
Ummon
« Reply #14 on: August 04, 2008, 04:52:20 pm »
Back_take 3
Sez.
A bit simpler is that you're a girl. Guys just don't do flowery-looking stuff like that.
Yo. Chocolate.
Stephen Hawking
missioncontrol
« Reply #15 on: August 04, 2008, 09:25:15 pm »
flip side to match my one of my other submitted designs:
« Last Edit: August 04, 2008, 09:41:19 pm by missioncontrol »
missioncontrol
« Reply #16 on: August 04, 2008, 10:02:49 pm »
Back_take 3
Sez.
why? You ascared you'll catch teh ghey?
sez
« Reply #17 on: August 06, 2008, 09:24:04 am »
Back_take 3
Sez.
Maybe you don't but real men do.  8)
Eat your greens
« Reply #18 on: August 06, 2008, 09:33:09 am »
In 1982.  :)
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #19 on: August 06, 2008, 04:51:11 pm »
In 1982.  :)
Isn't that about right for a forum where we discuss Pac-Man, Tron, and the like?  :)
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #20 on: August 06, 2008, 07:00:01 pm »
Sorry Chad, he's right.  :)
« Reply #21 on: August 07, 2008, 09:15:34 am »
Hell no.  He is just so manly he gets away with it.  Put that shirt on one of us and we're just a dork in an ugly shirt.  It may be 1982 in here but we do leave the basement occasionally.   :)
Ummon
« Reply #22 on: August 10, 2008, 11:23:34 pm »
Well, you know, there was that movie with Kevin Kline......
Yo. Chocolate.
Stephen Hawking
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #23 on: August 17, 2008, 12:22:24 am »
This one's great!
« Last Edit: August 17, 2008, 12:24:50 am by DeLuSioNal29 »
sez
« Reply #24 on: August 19, 2008, 09:39:41 am »
Last attempt from me.
Back design.
EDIT : Not sure why it's coming up oval shaped but try to picture it perfectly circular please :)
« Last Edit: August 19, 2008, 09:49:38 am by sez »
Eat your greens
« Reply #25 on: August 19, 2008, 01:03:48 pm »
Can't we just put Tom Selleck on the token?
dstone
    • Vectorcade
« Reply #26 on: August 19, 2008, 10:28:44 pm »
This one's great!
Well, I've managed to lose the AutoCAD and Illustrator files, so all I've got is a high-res JPG of this one.
I've been torn on the font selection... I posted in the other thread and didn't get any feedback. Anyone have any preference of one over the other?
sez
« Reply #27 on: August 20, 2008, 02:38:47 am »
I think that's the most sensible thing you've ever said.  If you've got time between all your other endeavours, make it happen.
Sez.
Eat your greens
« Reply #28 on: August 20, 2008, 09:30:35 am »
I'm afraid to do it this week.  This week so far has been full of epic fail.  My car died, then when the tow truck guy showed it undied, then my laptop died, and 4-5 other similar incidents so far this week.
On the plus side, this morning I found a dollar.
 :banghead:
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #29 on: August 21, 2008, 09:52:49 am »
I was thinking of going with something a little more simple than my design last year.   ;D
I whipped this up last night, still tweaking it...and I'm working on a front design to compliment it.
« Reply #30 on: August 21, 2008, 09:55:48 am »
I like that... I wonder how easy it will be, in real scale, to tell that those are letters.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #31 on: August 21, 2008, 11:11:01 am »
Quick re-hash of my idea from last year...
missioncontrol
« Reply #32 on: August 21, 2008, 11:16:09 am »
my finalized concept
mr.Curmudgeon
  • Huzzah!
« Reply #33 on: August 21, 2008, 01:07:48 pm »
Oh man....now you've got that damn song in my head!
missioncontrol
« Reply #34 on: August 21, 2008, 01:43:32 pm »
is it driving you crazy?
dstone
    • Vectorcade
« Reply #35 on: August 22, 2008, 01:46:46 am »
Bah, I give up. This is my final.
thatitalian
« Reply #36 on: August 22, 2008, 05:51:08 am »
I really like the outside ring on this design! Looks exactly like a token should look! Just needs something in the middle like the hall of cabinets design or the army of people design! Now that would be awesome!
edwardvci
  • Last login:February 23, 2009, 08:56:49 pm
  • Insert Coin.........!
« Reply #37 on: August 24, 2008, 09:45:54 pm »
Isnt that the STARGATE on SG1?
Pixelhugger
  • Last login:Yesterday at 05:12:30 pm
« Reply #38 on: August 25, 2008, 01:51:57 am »
To go with the hastily submitted front design. Obviously rough. Still a pencil sketch.
Project mega thread HERE
missioncontrol
« Reply #39 on: August 25, 2008, 07:27:31 am »
very cool pixel, both sides are outstanding... can't wait to see them cleaned up...
