Author Topic: Spinner you're using?...and your Mame Tempest settings?  (Read 5485 times)
Ummon
  • Trade Count: (+13)
« on: July 19, 2008, 11:57:14 pm »
What spinner are you using and what do you set the sensitivity at for Tempest?
I'm using a Tornado spinner and I set the sensitivity at 150. It seems to be the balance between skipping paths and being able to easily roam the board.
« Last Edit: July 20, 2008, 12:10:04 am by Ummon »
Yo. Chocolate.
Stephen Hawking
TheShanMan
  • Last login:October 16, 2023, 03:35:12 pm
    • My Arcade (updated 1/30/13)
Re: Spinner you're using?...and your Mame Tempest settings?
« Reply #1 on: July 20, 2008, 02:23:11 am »
As a matter of fact, I use a tempest spinner! ;D And I haven't found any need to muck with the analog settings. The default settings seem fine to me, though I don't exactly play it all the time.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: July 21, 2008, 01:49:44 am »
From our wiki page, looks like 150% is correct for the tornado:
72 teeth original / 48 teeth tornado = 1.5 = 150%
The extra notes on tempest included info you can use to verify if 150% is like the original (1 rotation of spinner = x movement in game.)
Robin
Knowledge is Power
Ummon
« Reply #3 on: July 21, 2008, 09:39:39 pm »
HM. I don't remember the original having such travel...but of course it might've, just didn't have the same spin time - which is why I think I might prefer the Tornado. I would like to get some time on an original though, just to check it out.
Yo. Chocolate.
Stephen Hawking
mrclean
    • Guscade
« Reply #4 on: July 21, 2008, 09:50:51 pm »
I'm using the TT2 from Groovygamegear, i use these settings :
Stock settings in MAME of:
Digital Dial speed- 20
Dial Reverse - Off
dial sensitivity - 100%
Not sure if i can improve it, I really don't play this game, more of an arkanoid person
2,370,650 Gun.Smoke
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #5 on: July 21, 2008, 11:00:29 pm »
Tron spinner with default settings.
Don't want to know if I should change it as it feels right.   :P
TheShanMan
« Reply #6 on: July 22, 2008, 12:06:38 am »
A tron spinner CANNOT feel right for tempest! I have one of each and they have a tremendously different feel to them. I know, you meant in terms of the analog settings, but I just had to jump on that because there is such a stark contrast between the 2 spinners.
Hoopz
« Reply #7 on: July 22, 2008, 07:33:54 am »
Perhaps I used the wrong word.  "Feel" isn't as accurate as "seems".  It seems to work well so I don't worry about it.
Better?   ;)
Ummon
« Reply #8 on: July 24, 2008, 01:05:51 am »
Dial Reverse - Off
WHEW. That's high. I have a TT2 (that I've played with but haven't mounted permanently in anything) and I have to turn the sensitivity down to like 7.
Better?   ;)
That's what I thought you meant. I'd be intererested in trying that out just to see.
Yo. Chocolate.
Stephen Hawking
Nornus
  • Last login:July 24, 2008, 03:35:43 am
« Reply #9 on: July 24, 2008, 03:32:25 am »
I'm using a TT2 set to 6% sensitivity, at 100% it's barely playable and certainly not authentic.  With a real Tempest knob you move about 5 steps with a 360 deg spin so keep dialing down that sensitivity until you hit that sweet spot.
RandyT
  • Last login:Yesterday at 11:46:17 am
    • GroovyGameGear.com
« Reply #10 on: July 24, 2008, 03:25:49 pm »
I completely misread that at first :)
Yes, don't even try 100%.  That's almost 17x the res of the original control.  6% will give you perfectly authentic control for Tempest.
RandyT
« Last Edit: July 24, 2008, 03:31:35 pm by RandyT »
