May 09, 2024, 04:10:33 am
From our wiki page, looks like 150% is correct for the tornado:72 teeth original / 48 teeth tornado = 1.5 = 150%The extra notes on tempest included info you can use to verify if 150% is like the original (1 rotation of spinner = x movement in game.)
First off, Hoopz is right.
Tron spinner with default settings. Don't want to know if I should change it as it feels right.
I'm using the TT2 from Groovygamegear, i use these settings :Stock settings in MAME of:Digital Dial speed- 20Dial Reverse - Offdial sensitivity - 100%Not sure if i can improve it, I really don't play this game, more of an arkanoid person
Perhaps I used the wrong word. "Feel" isn't as accurate as "seems". It seems to work well so I don't worry about it.Better?
I'm using a TT2 set to 6% sensitivity, at 100% it's barely playable and certainly not authentic. With a real Tempest knob you move about 5 steps with a 360 deg spin so keep dialing down that sensitivity until you hit that sweet spot.
