Main > Main Forum
Can you connect an iPac to consoles?
Pages: << < (2/2)
Hoe:
IPacs output scan codes... right?
You'd need to build a converter. You may be able to get away with a few 74 logic chips to rencode the serial pins. I'm not too sure on the actual communications of modern console controller ports (I miss the days of nes/snes using a 4021 for controler encoding)
jakejake28:
--- Quote from: anthony691 on June 06, 2003, 01:31:41 pm ---
--- Quote from: steve_pss on June 06, 2003, 11:08:48 am ---The I-Pac works by using joystick or button signals to emulate a coorenspoding keystroke. So unless your console could utilize a keyboard for control (and I'm sure it can't) your out of luck.
Check around this site, there are a number of people that have hacked (modified) control pad innards to work with real controls.
One word: Dreamcast ;D
There is a device that allows you to input PS/2 into your DC ;D
It is cheap too! Whats the dead system now? ;D
this device would allow an i-pac to be connected? how many simultaneous players. i have a 4-player ipac. could i get 2 players running off this deviece?
mahuti:
BTW the post with the link to the XArcade encoder is exactly what I'm talking about. I couldn't find a direct link to that anywhere on their site.
That' pretty much solves my dillemma.
Pages: << < (2/2)
Go to full version
