| Main > Buy/Sell/Trade - non-retail |
| Offering drilled (hollow) shafts for Joysticks |
| << < (9/9) |
| BurgerKingDiamond:
I need a hollow shaft for a LS-32. I went on Arcadeshop.de and they have them, but I don't want to spend $25 or more (i haven't done the exact math) for a joystick shaft. Any tips on doing this myself? |
| Luigi:
--- Quote from: BurgerKingDiamond on November 14, 2010, 01:24:34 pm ---I need a hollow shaft for a LS-32. I went on Arcadeshop.de and they have them, but I don't want to spend $25 or more (i haven't done the exact math) for a joystick shaft. Any tips on doing this myself? --- End quote --- Remove the shaft, look for one or more company and ask them if they can drill it.....they should do it for a small donation ;) |
| BurgerKingDiamond:
Thanks. If I had a drill press I could do it myself I think. It would be pretty difficult to do it with just a hand held drill. |
| Luigi:
--- Quote from: BurgerKingDiamond on November 14, 2010, 05:20:07 pm ---Thanks. If I had a drill press I could do it myself I think. It would be pretty difficult to do it with just a hand held drill. --- End quote --- If you want the maximum chance that it will work , you will need a lathe. A hand held drill won't work at all. A drill stand might be better but you have to make sure the shaft is exactly 90°. With a lathe the chance that the drill will break inside the shaft is still very high. Good luck!!! :) |
| robertsig:
Did anyone test if these drilled shafts can be used with Bender's trick to make a top fire U360 joystick? I don't need the LED. Thanks. |
| Navigation |
| Message Index |
| Previous page |
