Main > Main Forum
The perfect Arcade machine Motherboard??
rampy:
Even most of this is old hat let me chime in the following:
Most newer mobo's should have that power on after power failure option
Some frontends (minwah, others with a little utility) can shutdown windows/machine/etc when you exit the front end.
while we are on the topic... powering up your cabinet with 1 button can also be done doing a relay circuit, or by buying a fancy powerstrip (the easiest to find is the 20 dollar one at sears) that when you power up your PC it turns on your monitor power/marquee light/other aux power...
*shrug* let me know if you need more specific linkage
Rampy
