Main > Main Forum
Pac-Man cocktail cab
phizzle:
On My space invaders cocktail i cracked open a 13" vga monitor and mounted it like the original was, fits perfectly, perhaps you should get a 14" and mount it like the original was...
O| |O
O| |O
the space invaders had two bars across the middle of the cocktail, with holes to mount it on the tops of each, the monitor had holes on the corners to mount it, it was just a standard 13" monitor, it fit perfectly, i can get pictures if you would like.
