Author Topic: white ball top?  (Read 1666 times)
pinballwizard79
white ball top?
« on: July 12, 2008, 02:33:54 am »
Anyone know where I can score white ball tops that fit happ joysticks? :banghead:
NoOne=NBA=
Re: white ball top?
« Reply #1 on: July 12, 2008, 07:49:17 pm »
Wico made some way back when, but i haven't seen anything new.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: white ball top?
« Reply #2 on: July 12, 2008, 07:53:35 pm »
Failing that, try getting hold of some kind of plasti-kote style spraypaint and lacquer and you can colour the old ones yourself.
pinballwizard79
Re: white ball top?
« Reply #3 on: July 12, 2008, 08:23:08 pm »
Yeah I thought about spray paint.........just makes me feel dirty though.
But, it seems to be my only option.
thanks guys
Jdurg
Re: white ball top?
« Reply #4 on: July 12, 2008, 08:40:13 pm »
But after moderate use, wouldn't it just rub/flake/scratch off quite readily?
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Blanka
« Last Edit: July 13, 2008, 09:01:53 am by Blanka »
RandyT
  • Last login:Yesterday at 11:46:17 am
    • GroovyGameGear.com
Re: white ball top?
« Reply #7 on: July 13, 2008, 01:41:57 pm »
I can supply a Versa-Ball shaft in a color that is not "cue ball" opaque white, but it is white.
If you want one, just order a Versa-Ball and specify that you "would like a white top" in the comments section at checkout time.
RandyT
Ginsu Victim
  • Comanche, OK -- USA
Grasshopper
  • Last login:November 08, 2023, 07:20:31 am
Re: white ball top?
« Reply #9 on: July 13, 2008, 03:58:48 pm »
That just totally lost me. What was even going on here?
Kowal has the facility to make shafts to enable Sanwa or Seimitsu ball tops to be fitted to Happ joysticks.
pinballwizard79
Re: white ball top?
« Reply #10 on: July 13, 2008, 04:26:33 pm »
Right on guys. thanks!  :applaud:
Turnarcades
    • Turnarcades
Re: white ball top?
« Reply #11 on: July 13, 2008, 05:47:56 pm »
No, plasti-kote creates a proper rubber/silicone-like finish that is flexible, and the proper sealant creates a clear, solid seal - much like on a car.
Jdurg
Re: white ball top?
« Reply #12 on: July 13, 2008, 07:19:51 pm »
Ahhhh.  I see now.  I was just used to putting paint on plastics and having the paint flake off pretty quickly.
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
