Main > Main Forum
Designed my layout, opinions please.
mccall:
Are you going to be using an Ipac? If so you can take advantage of the built-in shift feature and you wouldn't need to have your admin buttons on the panel.
The Ipac shift keys come configured in default setting as: escape, tab, enter, tilde, pause and coin. The Ultimarc site has more info.
RedSquirrel:
--- Quote from: mccall on June 05, 2003, 10:11:19 pm ---Are you going to be using an Ipac? If so you can take advantage of the built-in shift feature and you wouldn't need to have your admin buttons on the panel.
Yeah, I am getting ipac. I just thought it might be nice to have seperate buttons for those things. Ive still got a while before I start building it so, nothing is concrete yet.
mccall:
If you are going to use the regular 2 player Ipac you won't have inputs for all those admin buttons. The two player Ipac supports 8 butons per player plus coin 1 & 2. You have 7 buttons per player and coin 1 & 2 on the panel. That leaves only 2 inputs free.
Hoagie_one:
im gonna make sure i have a big Pause button on mine. I get interrupted so much its a crime.
Minwah:
If you do use dedicated admit buttons, I'd seriously consider moving 'escape' and even pause away from those start buttons - you don't wanna quit while trying to continue!
