Main > Everything Else
DVD -> PC -> DVD
<< < (3/3)
Level42:
--- Quote from: Blanka on July 11, 2008, 02:38:26 pm ---Handbrake is more for ipodding DVD's.
The best format to edit is DV. Visual hub can make this from a DVD.
@level42: DV compresses too, but much less. It uses http://en.wikipedia.org/wiki/Discrete_cosine_transform compression.
I stand corrected. The fact is that there is no compression BETWEEN frames. So each frame is compressed and then stored. Whereas DVD compression (MPEG) takes a "first" frame and calculates the next x (often 15) frames from that first frame. That is what makes editing this format so hard.
Navigation
[0] Message Index
[*] Previous page
Go to full version
