Main > Main Forum
ps/2 trackball fire button
_Iz-:
you need to enable the mouse in mame.
If using mame32 then put a check beside mouse in the controllers section. make sure you do this in the default settings area. You need this to be global not per game.
If using regular mame then mouse=1 in mame.ini.
mclaught:
rebelscum, you are right, that was in the FAQ and I didn't catch it. I honestly don't think I would have known what I was looking for even if I did read that. At any rate, your link and directions fixed the problem, it is now working as I had hoped and I am eternally greatful. And I did mean NO instead of NC, I wasn't paying attention when I typed that I guess. Or I'm just dumber than I realize. thanks again.
