Author Topic: Need help understanding gpwiz49 pinout to gamepad mapping  (Read 1189 times)
m_mcgover
  • Last login:December 13, 2020, 09:19:55 pm
« on: July 03, 2008, 07:41:23 am »
I am confused about how the GPWiz49 pinout maps to joypad buttons.
I am in the process of trying to finish wiring up a control panel before our 4th of July party tomorrow (pressure, pressure! :o) and I'm at the point where I need to start wiring up 2 GPWiz49s.  I have the solder versions that I bought used.  They came already soldered up to 2 Williams 49 way sticks.  I've plugged them in and verified that the joysticks work properly.  Now, I am ready to wire up 4 buttons per player, a start/coin per player, and 1 pause/1 esc (14 total) -- I'll be using leaf switch buttons.
I have a bunch of questions that I'd like to understand before pulling out the soldering iron.
1) Is there some default mapping from the pinout on GPWiz49 PCB to gamepad buttons that I should follow?
I.e. right now, the 49 ways are soldered into 1-8, G, G, and V+ on the PCB (essentially the leftmost 12 positions on teh PCB, looking from the top).  Remaining pins are:
B D F H | J L N P | U D L R | G []
A C E G | I K M O | R L D U | G S
Does "A" map by default to a gamepad button?  If I test the joystick in windows, there are buttons 1-28.  How do buttons 1-28 map to the pinout above?  A=1, B=2, etc?  Some other way?  What are the G G and S all the way to the RHS of the pinout?
2) Is there a guideline or a standard I should follow to make my life easier when I configure mame?
3) I am using Mala, so I think I need to make sure my admin buttons are one of the first 12?
4) When I go to map gamepad buttons in mame, do I really have to do it for *every* game, or can I set up a default to be applied to all games?
Sinistar, 25" Smash TV, Major Havoc 720, Star Wars cockpit w/ESB kit, Robotron cocktail, Warlords cocktail, Back to the Future pinball
Paladin
  • Mmmm llamaburgers!
Re: Need help understanding gpwiz49 pinout to gamepad mapping
« Reply #1 on: July 03, 2008, 08:33:13 am »
Go to www.groovygamegear.com and check out the page for the gpwiz49.  Here's a direct link to the PDF on that page telling you what connections go where:
http://groovygamegear.com/PDF/GPWIZ49_MAX.pdf
When you start a game in MAME and hit the tab button, there's an option for setting up controls for all games and for the individual game you started.
m_mcgover
« Reply #2 on: July 03, 2008, 09:21:41 am »
Duh!   :banghead:
I am sorry for asking such an obvious question.  In my rush, I didn't look at that document carefully enough (the dangers of skimming pdf on a computer).
Thanks for the tip in mame, too.  I didn't realize that control selections could be applied across all games.
Thanks and again, sorry for the obvious question(s).   :-[
m_mcgover
« Reply #3 on: July 03, 2008, 09:33:40 am »
But now I have a new question...
In the PDF, there are two sets of UDLR labels.  Looking at the PCB with the pinout on the bottom:
Does
UDLR
RLDU
map to
1357
2468
or map to
8642
7531
RandyT
  • Last login:Yesterday at 11:46:17 am
    • GroovyGameGear.com
« Reply #4 on: July 03, 2008, 09:43:29 am »
The upper set is "1" and the lower set is "2".
The 40 pin header should show a P1 and P2 to the right.  They coincide with the above.
But here's a PDF that should make it easier for your board version.
RandyT
m_mcgover
« Reply #5 on: July 03, 2008, 09:48:15 am »
Randy-
Thanks.  That PDF answers my remaining questions.
Paladin-
Thanks for your help, too!
Now...off to the control panel.... ;D
