Main > Project Announcements
New Jukebox - Wurlitzer style - Spring construction has begun!
NiN^_^NiN:
Im guessing it's the bigger tube and not the bubble tube thats giving you the problem with bending it?
I looked into doing this years ago and i found some clear huge tubing just like the bubble tube you have which would bend easily.
Not knowing what tubing your using couldn't you do the wurlitzer style but instead of it being bent have it square?
could have the accent pieces on the top corners it think a square version of a wurlitzer with the lil viewing window would be cool
shardian:
Ahh, I found the reason why you decided to do this project...can't say I blame you! You have a proof of concept already to go by.
http://forum.arcadecontrols.com/index.php?topic=81207.msg847697#msg847697
I bet that thing would weight a ton though.
Franco B:
--- Quote from: shardian on July 08, 2008, 11:37:29 am ---Ahh, I found the reason why you decided to do this project...can't say I blame you! You have a proof of concept already to go by.
Wow! That thing is amazing! :o
mccoy178:
I finally was able to start cutting tonight. The video is kind of jacked up, but you can at least get the idea. :cheers:
[youtube]http://www.youtube.com/watch?v=e37zfdhMJE8[/youtube]
javeryh:
I can't believe you did all that in one night. It looks like everything was cut PERFECTLY too. I am jealous of your skills and your awesome woodshop. This thing is going to be great! :cheers:
