Main > Project Announcements
New Jukebox - Wurlitzer style - Spring construction has begun!
NiN^_^NiN:
I can tell you that pc modders who use water as a cooler use distilled water and water wetter mix which stops any type of algae growing
It's sold at pepboys (some american auto shop)
The bubbler wurlitzer used a chemical called Dichloromethane which is all toxic which i don't reccomend it was a closed system the heat from the bulbs created the bubbles.
I do believe there is an oil that is the same and will boil(create bubbes) with little heat and non toxic
Goz:
How about mineral oil it was frequently used in the 70's to make groovy stuff like Rain lamps, etc. If memory serves heat was applied and it did a bubble thing.
Havok:
Small!
8way:
Small.
Franco B:
Very cool buddy. 8)
You could always have two tubes next to each other, one with large bubbles and one with small. Or you could even have three - large bubbles in the center pipe and small ones in the outer two.
You could maybe even use different diameters of pipe (eg, one large pipe and two smaller ones etc)
