Main > Main Forum
Priming and spraying the cab. Recommended?
steve_pss:
I used rustoleom high lustre black laquer. I sprayed on a few light coats to let the MDF soak up a bit of paint, then I layed each piece flat and layed it on very thick. It's the only way I found to keep it from looking spotty and going through a ton of paint.
All that being said although my cab came out looking really nice I would use a foam roller next time.
thedemo:
I sprayed my cab using a Wagner Power painter. The finish came out awesome, nice and smooth, no lines or little pieces of fuzz from the roller.
