Main > Everything Else
Anyone every replaced their furnace?
<< < (2/2)
Jdurg:
That would be for a furnace/boiler combination, and also depends on location in the house.  E.G. how much work is involved in removing it and putting the new one in its place.
Hoopz:
Consider getting a heat pump also.  Takes less power to run it v. the furnace.  My heat pump runs by itself until temps get under 30 degrees, gets assistance down to 10 or 20 degrees, then the furnace takes over by itself under 10 (estimates on temps but fairly close I think).
ChadTower:
--- Quote from: Hoopz on June 29, 2008, 07:13:05 pm ---Consider getting a heat pump also.  Takes less power to run it v. the furnace.  My heat pump runs by itself until temps get under 30 degrees, gets assistance down to 10 or 20 degrees, then the furnace takes over by itself under 10 (estimates on temps but fairly close I think).
Geothermal?  What was the installation cost?  Was it retrofit or new construction?  What state?
Navigation
[0] Message Index
[*] Previous page
Go to full version
