Author Topic: Can I remove the fan from a Killer Instinct 2 Dedicated Cabinet? Too noisy.  (Read 1354 times)
amiga500
  • Last login:Yesterday at 03:24:06 pm
That's my question, I know I can replace it by a new one, but this cabinet is on only a couple of hours a week, not all day.
If I remove it, may the PCB or the Hard disk be damaged?
cheers :cheers:
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
The video card heats up pretty fast in my Gauntlet legends and it uses the same basic set up. I would replace the fan with a quieter fan before removing the fan and risk overheating damage.
Just my two cents.
Cheers
There are three kinds of people in the world those that can count and those that can't.
gatordad
  • Trade Count: (+11)
  • Last login:March 29, 2024, 07:11:02 pm
cheers :cheers:
Do me a favor and tell me what kind of monitor you have in there, make and model
I just got a KI2 that is missing the chassis.
GD
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
Just my two cents.
Cheers
^ What he said. Chances are if there's a fan inside the cab, it's there for a reason. Your first option when working with actual arcade hardware, should be to replace stuff that's not working instead of getting rid of it. If they put a fan in there, it's because the cabinet has a heat problem.
SirPeale
  • Green Mountain Man
You can try quieting it down.  If it's a DC fan, clean the blades well.  Look under the label, you will likely find a small plug.  Remove it and drop two drops of 3-in-1 Oil in there.  Replace the cap and clean the outside.  Put some tape over it.
If it's an AC fan, it's a little more complicated, but it also involves lubing it up.
Post a picture of the BACK of the tube in Monitor/Video.  Should be able to ID it from the PCB mount.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
bad bearings are usually the cause of fan noise. If oiling doesn't help, replace the fan with a new one.
NO MORE!!
