Main > Main Forum
scart tv socket audio
G1zm0:
i cut the ends of a pair of head phones, one has a blue and gold wire ( like bits of thread)
the other green and gold,
the gold ones will be ground and the other 2 l and r
will these be ok since they are like thread?
also woud wire work?
Zebidee:
Yes , the 'gold' wires (actually copper or copper alloy) are ground. The threads surround the other wires to reduce electrical interference. Twist the exposed threads together to make a wire.
The blue and green ones should be left and right. The only real reservation I have about saying this is that some cheap headphones only put a single channel (usually the left one) through to both speakers. Other than hooking it up and using your ears, The only way to be 100% sure is to use a multimeter and check connectivity with the jack plug sleeve connections, as shown in this pic from Franco B's post:
You can buy a cheap digital multimeter from a hardware store for about $10-15. Use the diode test function ( symbol looks like this: ->| )
G1zm0:
i tryed using meter. it tryed to do a continuity test but it didnt beep, thats why i was unsure of these type of wire, can ordinary wire be used?
Zebidee:
--- Quote from: G1zm0 on June 20, 2008, 05:07:42 am ---i tryed using meter. it tryed to do a continuity test but it didnt beep, thats why i was unsure of these type of wire, can ordinary wire be used?
Not sure what you mean. If you aren't getting any beeps at all, then you are probably aren't using your multimeter correctly
There is a guide to using multimeters posted here:
http://forum.arcadecontrols.com/index.php?topic=68787.0
G1zm0:
i swapped it out for another jack, that one must have been crap, and beeping ok
