Author Topic: What older console systems (PS1\PS2) have the arcade classics games?  (Read 1216 times)
y2kgtp
  • Last login:June 09, 2008, 02:02:40 pm
I blew my 5 in 1 Namco board somehow (was only 7$ shipped off of eBay) but wondered if
I should step up my cabinet build with a PS1 or PS2?
Which of these systems have a good selection of arcade classics on disk?  I figure this is the next step up
before I build a MAME cabinet, but I was saving that for an old 26" TV I have.
Ginsu Victim
  • Comanche, OK -- USA
Re: What older console systems (PS1\PS2) have the arcade classics games?
« Reply #1 on: June 09, 2008, 11:42:27 am »
PS2 has the best collections. Easily.
Namco, Midway, Neo Geo, Capcom, Sega, Williams, Gotlieb, etc
y2kgtp
« Reply #2 on: June 09, 2008, 11:48:07 am »
Cool.  And still cheap to find.  I assume the games can be played without the analog controls.....not sure if I would mess with adding those to a build.......
Ginsu Victim
« Reply #3 on: June 09, 2008, 11:54:26 am »
Also there's two Taito Legends collections, but they require analog (for some dumb reason).
You can pick up several of these at Walmart for $9.82 each.
severdhed
  • RIP Dinosaur Hippo
« Reply #4 on: June 09, 2008, 01:05:31 pm »
another nice thing about the ps2, is that you can make it a lightgun cabinet too.  get yourself a pair of guncon 2 controllers and a few gun games and you add a whole other dimension to your cabinet.  i am in the process of building a ps2 gun cabinet right now, and it is alot of fun.  i don't use it for anything other than gun games, since i have two other mame cabinets, but i thought about adding some external controller ports for playing guitar hero on it.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #5 on: June 09, 2008, 01:51:33 pm »
If you're doing a 'console-only' machine, go with PS1 or PS2. As well as the classics, you get a lot of neat arcade conversions from the 90's on the PS1, like Ridge Racer, Tekken etc., plus you can have Point Blank and Time Crisis if you pick up some G-Cons, like I did for my first machine.
Ginsu Victim
« Reply #6 on: June 09, 2008, 02:00:45 pm »
Seeing as the PS2 can play PS1, I see no reason to even consider a PS1 unless it's for budgetary reasons.
