Main > Project Announcements
Marvel Arcade - ARTWORK DOWNLOAD LINK
Pages: << < (16/33) > >>
Martijn:
is the monitor bezel as high as the monitor or lcd?
or how high is de visible lcd part verticaly?
thatitalian:
I'm not sure what you mean.
Martijn:
whats the size of the tv/lcd u will be using? height in cm of the screen part..
thatitalian:
Ahh, well it is a 19" (483mm) lcd monitor (not wide screen). The actual dimesions are 422mm (W) x 412mm (H) x 200mm (D). Its an AG Neovo F-419B. Approximately the screen part should be 342mm (H).
Is this relevant though? I need the lengths of the inside parts. The monitor will definitely fit the bezel, I just need to know the lengths the pieces should be according to those angles.
thatitalian:
OK, this is what I have got in terms of artwork (excluding the speakers, kickplate, keyboard tray and admin panel).
I made a few tweaks to the sideart, and I decided to create an admin panel that will house all the admin stuff (power, volume, pause, exit, reset) and move it of the CP. I also moved the spinner of centre to make it easier for aggressive trackball use.
Let me know what you think because if everyone is happy this is getting printed!
Go to full version
