Main > Project Announcements
Marvel Arcade - ARTWORK DOWNLOAD LINK
Franco B:
Well I had some spare time this morning so I had a go anyway.
The profile on the left is the one drawn with the dimensions from the top drawing, the second is with the 100mm radius that you added on the second page:
I extruded the side panels to 18mm and added the 600mm panels as best I could to the drawing on the second page.
Let me know if I can do anything else.
thatitalian:
OMG! THANK YOU SO MUCH! :cheers: :notworthy:
I really appreciate your help! I am so bad at doing the plans electronically! So have to revert to good old fashioned pen and paper!
I am due to draw up some fresh plans so that they are neater, would it be OK if you helped me out when I post them?
Generally, what do you think? Is there anything you think I should change? Does it look neat/clean?
THIS IS WHY I LOVE THIS FORUM!!! ;D
thatitalian:
OK, I was thinking about a few small changes (excuse the paint job, I'm at work!)
On the left:
I thought about making the parts where the arrow points to longer. The bottom arrow is where the keyboard tray and prob needs to be longer and the second arrow on top is the back support for the CP and prob also needs to be longer.
On the right:
I was thinking about mounting my one button push start on the bit where the arrow points to. That way it is out of the way and behind the CP.
You can also see how I plan to hide the castors on the bottom of the cab.
Franco B:
Your more than welcome :)
Okay, I made the two changes. I also put a 100mm rad on the section just below the keyboard draw to even it out a little.
(old profile on the left, new one on the right)
And the model:
I imagine you want the cp shelf at the same height so I left that where it is and extended the other sections by 50mm.
The depth of the monitor needs adjusting on the new model but I can do that tomorrow morning, im nearly late for work!
thatitalian:
:notworthy: :notworthy: :notworthy: :notworthy: :notworthy:
That looks way better! THANKS!
Great assumption on the CP, I did want that at the same height!
I was thinking of having the monitor part slightly angled more upward so I could have the bezel angled but that it wouldn't be too far down. (see attached)
In terms of angles and sizes, will the program you are using tell you the correct angle and sizes to use? If so, WOW! That would save me SO MUCH time and money it would be unreal!
In return, if you need help with any artwork I will do my best to help, but judging by your computer skills I doubt you will! But the offer is there!
Again thanks for the help!
BTW, great work on the ARK project, those U360's look insane!
