Main > Project Announcements
Marvel Arcade - ARTWORK DOWNLOAD LINK
Pages: << < (22/33) > >>
beanboy33:
Well, the button spacing is pretty much the same as Thatitalians.  I think its fine and my kids 7 and 8  seem to have no problems.  But if you notice i moved all p1 and p2 buttons down a little.  on your cp the left and right arrows of the joystick and the trackball are at the same level.  on mine they are an inch or so apart.  the track ball is a 3" U-Trak from Ultimarc.   I just printed the artwork on a plotter here at work and put it under plexi glass.  nothing too special about it.  if you want i can post my cp artwork and you can over lay it on yours to see the button changes.  and lastly i am using maximus as a fe with a 27" tv.
thatitalian:
Yeah that would be great to see the comparison!
A 3" trackball? That is a worry as the red circle is supposed to be 3" exactly but there is a red ring around your trackball. Did you edit the red circle? (it was supposed to be just a placement to see how the trackball would look)
Just thought I would let everyone know also you get an 11% discount at mame marquees! Will be ordering this within the month!
beanboy33:
ya, i made that circle larger.  i liked the way it look with a ring around it.  i also extended the black boarder around the outside of the cp
thatitalian:
Ahhh, I almost crapped myself thinking the dimensions were all wrong!
Where did you print it up in the end?
BTW: I am working on a skin for MA, I know that beanboy has been waiting a LONG time for this but I will be releasing it at the end of next week once it is finalised.
(..... and no, you can't have a sneak peak! hehehehe ;) >:D)
beanboy33:
here at work i have a color plotter.  so, the cp and the marquee is printed on regular paper and sandwiched between plexi glass.  and remember, all the changes i did were from your original design at the start of the thread.  not the one you have towards the end of the thread.  I also added a pinball plunger.
Go to full version
