Main > Main Forum
Alternative to painting a hinge
fixedpigs:
--- Quote from: efjayel on June 08, 2008, 04:47:46 pm ---I would suggest replacing it. If not then at least remove it, paint the cab then put it back on. I know it's a lot easier to paint over it but it looks like ass when someone paints over a hinge. Sloppy work. I hate seeing that.
http://forum.arcadecontrols.com/index.php?topic=74322.0
Turnarcades:
Eugh!
SavannahLion:
--- Quote from: jhartley111 on June 08, 2008, 04:41:40 pm ---So you're saying I should leave the actual hinge unpainted and just use oil? if so, what to use besides WD 40 since it attracts dirt?
Just about anything actually. WD-40 is an awesome oil. Removes rusts, loosens bolts, lubricates in a pinch. But when dirt is a concern, I tend to avoid it.
Try using an oil specifically designed for bicycle chains. It's non-dripping so that will minimize stains on your cabinet. Penetrates through the close tolerances of the metal. Does a pretty darn good job of resisting moisture and dirt. I don't have a brand name for you though, but any well equipped bicycle shop will carry it. If they're nice they might even fill up a small applicator bottle with their repair shop supply for a dollar or two.
TheShanMan:
I built a metal panel for my centipede, and I just bought a new piano hinge and primered and painted it and it looks perfectly fine to me. I painted it black though, not pink. :P
boogieman:
You could use gun bluing, or you could buy a brass piano hinge (probably big bucks though...)
Personally, I wouldn't be worried about the paint looking bad unless its out in the open. Do you have any pics?
