Author Topic: Easiest way to hook up Dreamcast to Arcade cabinet  (Read 2298 times)
falcons7
  • Last login:May 10, 2015, 11:47:48 pm
« on: June 06, 2008, 09:26:17 am »
Hello I am somewhat stuck on what route to go in order to get my dreamcast running in my cps2 cabinet. I have a Wells Gardner monitor inside the cabinet. I currently purchased a naki dreamcast vga box and a vga to RGB/H/V cable.... Please help :(
abzman2000
  • Last login:August 26, 2020, 06:25:12 pm
  • I LIKE my hat!
Re: Easiest way to hook up Dreamcast to Arcade cabinet
« Reply #1 on: June 06, 2008, 01:11:23 pm »
http://www.gamesx.com/wiki/doku.php?id=av:dreamcastav
this seems to say that the dreamcast does 15kHz stock, so I think you would have to hack that cable or something
falcons7
« Reply #2 on: June 09, 2008, 11:15:33 am »
I knew that part although I wanted to know once i cut the ends off of the cable that I have what do i plug the wires into?
abzman2000
  • I LIKE my hat!
« Reply #3 on: June 09, 2008, 11:22:31 am »
oh, well you should need the RGB ground h-sync, and v-sync lines
and jump pin 6, or 7 but not both to ground
falcons7
« Reply #4 on: December 07, 2008, 06:09:37 pm »
i have taken pictures of what seems to be the molex connector on the back of my monitor that contains RGB/H/V. Does anyone know which wire is which, cause if seems to me that the red, green, are the first two, then it seems like a brown? grey and yellow. what is the brown one for?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #5 on: December 07, 2008, 06:27:28 pm »
You are going to have R/G/B, Video Ground and at least one Sync (negative composite), depending on your monitor.
What is your monitor ?
Working: Not Enough
Projects: Too Many
Progress: None
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« Reply #6 on: December 07, 2008, 06:31:57 pm »
the arcade connector goes in this order.
RED
GREEN
BLUE
GROUND
Sync
the brown is sometimes the blue, the ground is black and thw white is sync.
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
CheffoJeffo
« Reply #7 on: December 07, 2008, 06:50:31 pm »
RED
GREEN
BLUE
GROUND
Sync
While I agree that you are probably right in this case, you really can't rely on wire colours.
I have a G07 (as pulled from the cab) on my bench right now where the individual wire colours bear no resemblance to "reality".
Also important to understand the difference between positive and negative, hori and vertical syncs and to know what your source expects (although likely negative composite in this case), so you don't waste time trying to sync different signals.
Not trying to be pedantic, just trying to be clear in case others read the thread and wonder why stuff didn't work for them.
Working: Not Enough
Projects: Too Many
Progress: None
ctozzi
« Reply #8 on: December 07, 2008, 08:59:18 pm »
that's cool I have the same connector on 3 of my cabs so i fugured it's exactly the same, but could be a bit different, however he only has 1 sync wire.
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #9 on: December 08, 2008, 01:22:23 pm »
Emulator would be the easiest way for me.  ;)
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
falcons7
« Reply #10 on: December 09, 2008, 10:55:18 am »
The monitor is a Wells Gardner 25K7197. Can anyone confirm if the colours are what was posted above?
CheffoJeffo
« Reply #11 on: December 09, 2008, 11:48:26 am »
I never trust wire colours -- I even check the voltages on PC power supplies.
Based on the pictures and the monitor's documentation, I concur with ctozzi's assessment.
More documentation for your monitor is available from WG:
http://www.wgec.com/service/
Working: Not Enough
Projects: Too Many
Progress: None
