Main > Everything Else
Network Attached Storage, strange slowness
<< < (7/7)
sirwoogie:
--- Quote from: boykster on June 16, 2008, 02:34:18 am ---I just setup my new 12 port....
Thank you for the manhood measurement.  :)
boykster:
--- Quote from: sirwoogie on June 17, 2008, 03:25:39 pm ---
bishmasterb:
shmokes,
You've probably already got this figured out, but I wanted to let you know that I was at a site that had a Terastation today and thought I'd test it out.
(BTW, I realize that, as others have pointed out, I didn't initially make the distinction between moving and copying, my bad. Yes, moves should be nearly instantaneous.)
File moves to the same share were nearly instantaneous.
Files "moves" (forcing Windows to "move" the data) to different shares (UNC paths) on the SAME Terastation volume behaved like file copies (i.e. slow).
Navigation
[0] Message Index
[*] Previous page
Go to full version
