Main > Everything Else
Network Attached Storage, strange slowness
bishmasterb:
Oops, that could have been more clear.
You might try doing a backup to USB, and then seeing if the restore function will let you specify a target folder. Now that I think about it, I'm not sure I recall seeing a "restore" option on the Buffalo's web admin utility, so perhaps the designers just figured you do a restore initiated from a workstation...and then of course, you're right back where you started.
Spaz Monkey:
Let me state that I know nothing about how the NAS drive works, but could you just pull the disk out, attach it to your desk top, copy files, and re-install the driive?
bishmasterb:
--- Quote from: Spaz Monkey on June 08, 2008, 01:08:34 am ---Let me state that I know nothing about how the NAS drive works, but could you just pull the disk out, attach it to your desk top, copy files, and re-install the driive?
If it's part of a RAID array, that won't work. If it isn't part of a RAID array, and it's an NTFS volume (which I assume it is with the Buffalo NAS units) that just might work.
shmokes:
It's a four-disk RAID 5 array.
boykster:
PEBKAC?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
