| Main > Main Forum |
| Neo geo thumb button... why not a pinky? |
| << < (2/2) |
| lettuce:
--- Quote from: GinsuVictim on June 05, 2008, 08:45:17 pm --- --- Quote ---Could you just have a "pinky button" like this? : 4 5 6 1 2 3 4 --- End quote --- Like me? Mine has the fourth wired twice 456 123 4 --- End quote --- How did you do that? are you using the wire harness from the U360 sticks, did u just dasiy chain button 4 and (4) 5 to one another, ie 1234 4(5)56 |
| Ginsu Victim:
All buttons on the control panel are running through a Minipac. Only the second player stick has a harness wired in, and it's only running admin buttons hidden under the flip-up panel on the front of my CP. As for how it was wired, you simply run the wire for button 4 to both buttons (I just ran two wires into a male crimp connector and plugged that into the button 4 female connector). I have since rewired it and made a second Mamewah system entry for only Neo Geo games in MAME, rather than using a CTLR file. My new setup is: 456 123 7 |
| RoomTenONine:
We talked about this before. A real easy way that will let you avoid having to mess with key mapings is: 1234 456 This way you have the 1-4 Neo style on top and the 1-3 over 4-6 Capcom style as well with no need to remap. A lot of people do the following, but have to remap. 123 456 7 I'm still on teh fence about what I want to do for my new CP, but I'm leaning towards the first one since all you have to do is wire both #4 buttons together. |
| Ginsu Victim:
It comes down to where you like your 1 button to be. I prefer to play mostly on the bottom row, and I don't care about Capcom fighters enough to care which row is punch or kick. |
| RoomTenONine:
--- Quote from: GinsuVictim on July 22, 2008, 01:14:55 pm ---It comes down to where you like your 1 button to be. I prefer to play mostly on the bottom row, and I don't care about Capcom fighters enough to care which row is punch or kick. --- End quote --- I'm pretty much the same except some of my friends are die-hard Capcom fans and would hang me if I switched them. |
| Navigation |
| Message Index |
| Previous page |
