Author Topic: New project, as yet un-named (updates)  (Read 3928 times)
abzman2000
  • Last login:August 26, 2020, 06:25:12 pm
  • I LIKE my hat!
« on: June 02, 2008, 07:30:05 pm »
yay, I finally got a machine to play with off of craigslist, first I would appreciate it if someone could identify it's origin, I don't think it's always been a battletoads.  some water damage has been painted over and of all things a blacklight installed.  have a look, I'm in the planning phase right now so any suggestions on where to go from here is helpful.  I have big plans for this cabinet and they will be revealed as my options become clear to me.
picasa (main cab pics) http://picasaweb.google.com/Abzman2000/Arcade
flickr (detailed pics) http://www.flickr.com/photos/20064083@N00/
things to do:
get new locks
fix / replace coin mechs have mechs and repair parts, those and door are wirebrushed and need clr + paint/clearcoat
new wheels, 2 fixed, 2 casters (these are uneven and all are fixed) installed 4 smart casters
install monitor
sand/repair bottom edges (done sanding)
fill holes (I'm thinking of using conventional bondo)
sand/strip paint done
I have decided to break up my build into smaller question / answer threads, so far I have these:
cp design thread here
monitor mount thread here
monitor repair thread http://forum.arcadecontrols.com/index.php?topic=91568.0
finish date: May 1 2009
« Last Edit: April 16, 2009, 03:36:10 pm by abzman2000 »
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
Re: new project, as yet un-named
« Reply #1 on: June 03, 2008, 08:34:20 am »
Ha!  That was on detroit's craiglist yes?
You beat me to it.  I never heard back from the guy on Saturday, but he said he had someone else interested and I would be next up if that person didn't come through.
Now that I see it though, you've got your work cut out for ya.
Don't know what cab it is though. :dunno
Nice score for the price though.  :cheers:
gonzojoey
  • Last login:August 30, 2020, 10:26:44 am
« Reply #2 on: June 03, 2008, 04:27:38 pm »
Hard to tell what this was from the pics. Looks like an early 90's Midway style cab to me (NBA Jams, Killer Instinct, Hang Time, Wrestlemania, etc). Was the original CP the box type that sat on top or does it look like it was the same width as the cabinet. I'll keep looking thru KLOV for some look-a-likes for ya
abzman2000
  • I LIKE my hat!
« Reply #3 on: June 03, 2008, 04:28:07 pm »
you got me.  when I answered him he said someone else was already considering it, but "first come-first serve" so I picked it up at around 8 that night.
abzman2000
  • I LIKE my hat!
« Reply #4 on: June 03, 2008, 04:30:10 pm »
the t-molding lines go all the way down the sides, and I assume the holes were cut to route wires so I'd say the original cp had to be no larger than the sides.
abzman2000
  • I LIKE my hat!
Re: New project, as yet un-named
« Reply #5 on: June 06, 2008, 02:46:40 pm »
I have a lock (only one, and it's temporary) so I will be attempting to install it within a few days.
I have decided that I will need cup holders on this cab, but no ordinary cup holders, dowels / rods coming up from the sides of the cp (I have not decided exactly where) to hold a max of 4 "ultimate gulps" from 7-11.  I have one, and so do just about all my friends ($1.25 for a 2 liter of slurpee, how much better can it get).  these mugs measure 5.5" in diameter, but the handles are hollow and have a hole in the bottom so I figure a rod for the handle requires less work than getting actual cup holders.
« Last Edit: June 06, 2008, 02:51:06 pm by abzman2000 »
abzman2000
  • I LIKE my hat!
« Reply #6 on: June 11, 2008, 08:15:45 pm »
the dimensions of this cab look an awful lot like The Simpsons arcade game without the cp box, the speaker holes match too.  does anyone know of a game that used a similar cab, but had the cp confined to the sides of the cab?
abzman2000
  • I LIKE my hat!
« Reply #7 on: June 30, 2008, 10:24:17 am »
I have the set of speakers that I am going to use, an altec lansing ACS-400 system.  I got them at a garage sale for $10 and I think they are... well I don't know what they are (there are 3 speakers in each satellite as well as a sub).
this explains it: http://cgi.ebay.com/ALTEC-LANSING-SURROUND-MULTIMEDIA-SPEAKER-SYSTEM-_W0QQitemZ190230513793QQcmdZViewItem?IMSfp=TL0806191286r4430
If I can't figure out how to mount them discretely with the original holes only I may use my current computer speakers (altec lansing vs 2121 2.1 system) and use the acs-400 as my main speakers.
From now on I will be operating as if this cab was originally a simpsons cab since all aspects except the cp point to that.   it's not a simpson's cab, as the simpson's cab had a big box on it, and this one did not (have a look at a simpson's cab without the box on it)
I also may have been over-zealous with my choice of monitor, it's a gateway destination 27".  It takes vga input so I thought it was perfect but it may be too big, it was only $20 and I may build my first custom cab around it if it won't fit in the simpsons cab.
« Last Edit: April 06, 2009, 02:08:52 pm by abzman2000 »
abzman2000
  • I LIKE my hat!
« Reply #8 on: April 06, 2009, 02:02:25 pm »
ok, news: I have been sanding, lots, I'm almost done and I'll post pics when I get the oppurtunity to do so, I've also patched the notches cut into the sides right below the cp.  I'm wondering the best way to sand an inside corner, I'm thinking probably a piece of 2x4 wrapped in sandpaper to get in the corners.  Another thing, it's been so long since I've researched this, but how would I go about repairing water-damaged mdf? I was thinking that I might be able to saturate it with fiberglass resin and then it might be good, I'll do some more resarch on it and then get back on my gameplan, finish date set for May 1 (this cab is going to penguicon with me for my friend's room party)
