Main > Main Forum
Best Nintendo white t-molding ?
Level42:
Jimkirk, did you receive it yet ?
jimkirk:
--- Quote from: Level42 on June 23, 2008, 12:59:35 pm ---Jimkirk, did you receive it yet ?
I received my t-molding from mikes arcade and it is a little flatter than the t-molding.com stuff. The t section is thinner so it should lay flatter when installed other wise it looks the same. Dull finish with a slight hump in the middle like all the rest of the t-molding I have seen. I have bought from 3 different sources and mikes is the one I would buy if I had to choose one. Hopr this helps.
JIM
2600:
--- Quote from: jimkirk on June 24, 2008, 03:14:28 am ---
JIM
Got any pics of them separately or together?
Level42:
Thanks. This confirms my decision to keep the original T-molding. I guess when it's really bad, Mike's the best to go with. Still I'd like to see some pictures if possible.
Level42:
Shameless bump for pic-request :)
