Main > Main Forum
How to connect multiple pcbs to one stick?
Pages: << < (2/3) > >>
TomJBart:
G'Day
At the moment I'm using a printer switch box (paralell cable switch box) to switch between a Gamepad and a Keyboard.  This does the job OK but I need to do this for player 2 as well meaning a 2nd switch which is a pain.  You also have to be careful that the switch you buy switches all pin / wires, not just the ones require by a printer.  Not that the store usually has any idea?
Because of this I'm going to give the Control Circuit from http://www.russprince.com/cabinet/ a go...
Has anyone else tried this ??  If so do they some more detailed instructions on how to hook up the CMOS IC's ??
Cheers
SNAAAKE:
--- Quote from: TomJBart on June 03, 2003, 01:36:24 am ---G'Day
Cheers
Does your paralell switch box have any PCB inside ???
I later found that my 25pin printer switch box HAD a pcb and might have been only switching ground !  :-[.
It worked between psx and dreamcast but it was laggy..like I press something and it works after like atleast 2 second.
Thats how it went for me !
never bothered trying again...I now use molex connector and very happy. :)
even with switching manually(atleast it works).
TomJBart:
Nope, No PCB,
I just use a manual switch, something like the "2 way D25 Computer Data Switch" @ www.jaycar.com.au
They are cheap and easy !
SNAAAKE:
--- Quote from: TomJBart on June 03, 2003, 02:02:42 am ---Nope, No PCB,
YUP...just when I thought mine would work..DIDNT !  :-[
anyhey..another question,do you have any other interface in there?
like atleast 2 different gamepads ???
Just wondering...thinking I should try again !  :o
SirPoonga:
Found it
http://multigame.com/jamma.html
Go to full version
