Main > Main Forum
NEW LCD Topgun driver
Pages: << < (3/3)
Organic Jerk:
--- Quote from: aljupy on June 03, 2008, 04:03:34 am ---Yup, but I think it is pretty well explained in page 47. Around from the middle to the bottom.
Even with some Snapshot  ;)
-Regards
Umm... That works..   :angel:             :soapbox: ::)
I didn't think people were still updating that immense thread...
deano728:
Dumb question, but I thought I'd ask since I'm not that smart.  I had been using mame32ui and just switched to using mame.  My lightguns work in mame32ui, but not when I try using it through mame.  What settings do I need to put into mame.ini in order to make this work with mame?
headkaze:
Try the following
--- Code: ---#
# CORE INPUT OPTIONS
lightgun        1
# CORE INPUT AUTOMATIC ENABLE OPTIONS
lightgun_device           lightgun
--- End code ---
deano728:
Thanks Headkaze!  I will try it out when I get home from work.
u_rebelscum:
If that doesn't do the trick is to open the "old" mameUI32 ini folder, and look at the settings in the mame.ini file (if you still have it).  Compare that to the "new" mame.ini in the mame folder.  Look in the input sections noted in headkaze's post.
But do as headkaze said first; those are the most probable things that are different.
Pages: << < (3/3)
Go to full version
